But I have a quotation to have mine Rebuilt with Metal that does not break out of a Window Repair place in Arizona and will do this as the stock ones are not robust and just replacing the regulator with the stock one would not be a permanent solution. They have been very responsive, and it comes with a lifetime warranty.
Here is the place that has been recommended on this site with good results. I have a quote from them.
https://powerwindowrepair.com/
John
Let me know how that goes. You can have a company in Arizona rebuild your failed regulator. I'm going down that route right now.
Hey guys, any update on the
PowerWindinowRepair place in Arizona?
Gotta deal with this myself. Both Windows!!
Passenger window sounds like the usual failure of the tubing over the spring cable line (noise on rise). But can lower and raise 1/2 way without any issues.
Driver window is different. Not exactly sure what broke yet. On lowering, the rear of the window drops faster than the front and can get a bit jammed up.
Have learned I can pull the rear of the window up again by hand to level it out again. Not sure what's wrong.
Have also learned that if I use short bursts on the switch can crack it open and close without too much problem.
But needs to be fixed!!
Hope to hear from you soon, thanks!
