Here are the specs:
GoPro’s HD Motorsports HERO is the world’s highest performance 1080p HD on board video and still photo racing camera. Professional quality 1080p, 960p, and 720p HD resolutions records the action at 30 frames per second (60 fps in 720p). The HD Motorsports HERO easily mounts to any helmet, motorcycle, ATV, car, plane, jet ski, boat, snowmobile or other vehicle. The camera’s quick-release mounting design makes it easy to re-position the camera around your vehicle for professional quality HD video from several angles.
Record up to 2.5 hours on a single charge and up to 9 hours total on a 32GB SD card (not included).
GoPro’s obsession with sound has conquered the wind. At 85 mph on a motorcycle, you’ll enjoy the throaty sound of your motor, not the wind. Inside even the quietest street cars, hear the pull of your motor…not the drone of the wind and road.
The camera can also shoot automatic 5MP time lapse photos at 2/5/10/30 and 60 second intervals during your drive or ride, hands free. Press the shutter button once and record up to 2.5 hours of on board action with poster-print quality photos.
Included are mounts for two helmets and three vehicles, as well as a suction cup for maximum versatility and convenience. Also included is a 1100mAh rechargeable lithium-ion battery that lasts for up to 2.5 hours of constant recording. With optional accessories, you can also plug the camera into a wall outlet, cigarette lighter, or with any USB-compatible power adapter, wire it directly to your vehicle’s electrical system. The battery will charge while you record.
Waterproof to 180’ / 60m and protected from rocks and other hazards thanks to its removable polycarbonate housing. Replacement housings and lens kits are available, making repairs or refurbishing your HD HERO camera affordable and convenient. It’s a GoPro…go for it.™
[h=2]What’s Included:[/h]
- 1 HD HERO Camera (5 megapixel)
- 1 Rechargable 1100 mAh Lithium-Ion Battery
- 1 Waterproof Quick-Release Housing (180’/60 m)
- 3 Flat, 3M™ Adhesive Mounts
- 2 Curved, 3M™ Adhesive Mounts
- 2 Quick-Release Buckles
- 1 Vertical Surface “J-Hook” Buckle
- 1 Suction Cup Mount
- 1 Three-Way Pivoting Side Arm Assembly
- 1 USB Cable
- 1 Component Video (HDTV) Cable
- 1 Composite Video + Audio Out Cable
- Warranty: One Year
[h=2]Tech Specs:[/h][h=3]Camera Optics[/h]
- Lens Type: Fixed Focus (2ft/.6m – ∞), glass
- Aperture: f/2.8 (high performance in low-light situations)
- Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
- Angle of View: 127º wide angle in 1080p mode
[h=3]
Video[/h]
- HD Video Resolution Modes: (subject to change, pending final firmware release)
- 1080p = 1920×1080 pixels (16:9), 30 fps, 15 Mbit/s data rate
- 960p = 1280×960 pixels (4:3), 30 fps, 12 Mbit/s data rate
- 720p = 1280×720 pixels (16:9), 60 fps, 15 Mbit/s data rate
- 720p = 1280×720 pixels (16:9), 30 fps, 8 Mbit/s data rate
- WVGA = 848×480 pixels (16:9), 60 fps, 8 Mbit/s data rate
- Sensor Type: 1/2.5″ HD CMOS, 2.2µm-sized pixels
- Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
- Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
- Exposure Control: Auto with user selectable center weighted average and spot metering settings
- White Balance: Auto
[h=3]
Audio[/h]
- Microphone: Built-in, mono with AGC (automatic gain control)
- Audio Format: 48 kHz, AAC audio compression
[h=3]
Photo[/h]
- Resolution: 5 megapixel
- Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
[h=3]
Storage[/h]
- Memory: SD card (SDHC), up to 32GB capacity (not included)
- Average recording times (using 32GB SD card):
- 1080p (30 fps): 4h 21m
- 960p (30 fps): 5h 26m
- 720p (60 fps): 4h 21
- 720p (30 fps): 8h 09m
- WVGA (60 fps): 8h 09m
[h=3]Camera Connectors & Cables[/h]
- PC Connection: USB 2.0 (data connection and battery charging)
- HDTV Out: HD NTSC & PAL (component cable incl.)
- Audio Out: Combo 2.5mm jack with stereo audio and composite video out
- PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.4.11 and later
[h=3]Power & Battery[/h]
- Battery Type: Rechargeable 1100 mAh lithium-ion
- Battery Life: Approx. 2.5 hrs
- Charging: via USB to computer or optional power adapter
- Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
[h=3]Waterproof Camera Housing[/h]
- Depth Rating: Up to 180 feet / 60 meters
- Construction: Polycarbonate and stainless steel
- Hardware: Stainless steel
[h=3]Size & Weight[/h]
- Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
- Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
[h=3]Optional Accessories[/h]
- Additional Rechargable 1100 mAh Lithium-Ion Battery
- Full Line of Mounting Accessories
[h=3]Optional Expansion BacPacs™[/h]An innovative expansion port on the back of the camera, the HERO Bus™ accepts optional Expansion BacPacs to expand the functionality of HD HERO cameras:
- LCD BacPac for on-camera preview and playback
- Endurance Battery BacPac for double battery life
- More BacPacs and expansion devices coming soon
