phiebert
OK, I posted the fact that my interior light stays on with the door closed but now I'm becoming baffled and need some guru advice.
The problem: Interior light stays on when doors closed on '94 RT. Light switch on mirror is set properly, headlamp switched is dialed properly, doors closed properly.
Added intrigue: Today I turned the ignition on and with both doors closed the chime doesn't sound. But when I open the driver's door the chime starts (as it should). So that must mean the door contact is working properly in that door. Now for the other side. When I open the passenger side door I can hear a relay/contact click under the dash by the steering column. Now that must mean that the contact in the passenger door is detecting open and closed properly too right?
So what is turning the interior light on? I am trying to solve this by any means but opening up the doors (which I've done before and don't feel like doing again if I can avoid it!).
I'd appreciate any advice. Thanks.
