I've been reading the archives and doing a lot of research on vipers in the last month, and i've been running into some conflicting information that I was hoping the board might be able to clear up.
1. Headgaskets.. This is a known failure point it seems.. From what I've read, most gen I cars will have this problem at some point. A couple questions I have for this though.. A)Does this mean you have to have a engine rebuilt if your head gaskets go or does it mean you can just get your head gaskets replaced???
B) In reading the Viper changes over the years, this site claims that head gasket material was changed in late model 94 vipers. Does this mean that those with the new material in late 94 are not affected by leaking? C) is there any way of looking from the outside of the engine and determining type of head gasket/ material used? If not, is there a certain vin## where all vins past that point used the new material?
2. Extended Warranties.. Does anyone know the criteria requirements to get an extended warranty on a purchase of a used Viper? This instance would be applied to a 1994 with 27k miles. The main interest of course is caused by all the reading about the head gasket failure rate.
Thanks!
-Bruce
Thanks!
-Bruce
