SnakeBitten2k14
Hello All,
I wanted to introduce myself to this forum. Some of you may have seen from the "other forum" but I'd like to share my excitement to all
I just took ownership of a beautiful Blue/White 1997 Viper GTS on May 2. This car has been fully documented since late 1997 when it was purchased and I have documentation of all mods including a Hennessey Venom 500 package (I believe this is just Hennessey exhaust system). The car has a dyno chart of 430rwhp/460rwtq.
I've only driven the car for about 20 miles to my house due to needing to wait for the title to come from the credit union to properly register the car, but within that short drive, I've had multiple thumbs up and looking over one time with a camera phone pointed straight at me recording the car. Needless to say this car is a timeless piece of history and I cannot wait to make memories with it.
I had a few questions that I initially posted on the other forum but have modified this post to address some of the responses I've heard. Any further insight from you all is much appreciated.
Passenger Rattle
I took the car for a drive and at idle there seemed to be a rattle on the passenger side. When I drove the car back there was no rattle. Thought the door was loose, but it seemed to be closed solid. Previous owner believes that it is due to an old clamp that he replaced in the exhaust and it may be loose. I plan to address this based upon my comments in the "Hot Sills" section.
Lowering and Scrapes
Although not advertised, I believe the car has been lowered. The front looks lowered but the rear still seems high. I have a documented receipt where the shop installed suspension parts (lists "Suspension, bushings, sway bars) but doesn't list the details of the parts. Sadly, I have a steep incline into my complex and even going slow at a angle, I heard a scrape. I've owned a lot of low cars (Miata on coilovers, two FD RX7s, etc.) but the Viper seems inclined to scrape a lot more.
I also noticed some kind of tape (seems like electrical tape) on the sides of the bumper to help protect it. In addition, there are 3 metal-like brackets that are duck taped to the underside of the bumper.
Hot Sills
Side sills are getting hot as I expected. The exhaust consist of headers to cats to resonator to muffler delete. I want to avoid any potential discoloration to the sills and will plan to bring the car catless and running just the resonator. I'm going to talk to a shop where I can get the side pipes to have a section where I can just clamp in the straight pipe or cats for when I need to go smog the car. If any of you have a similar setup, pictures of the setup would be appreciated.
Brake Rotors
The car has 14" brembo kit up front and the brakes squeal when braking. Brake pads are still good just looking if there is any way to quiet them down? I'll also need to clean the rotors as it looks as though the brake dust has clogged the drilled out parts.
Future Plans
- Full Viper tech inspection
- Full detail/claybar
- 5% Window Tint all around
- Easy to change cat/catless exhaust section
- Any other recommended mods for reliability?
Passenger Rattle
Hot Sills
Brake Rotors
Future Plans
