onerareviper
HELP! I\'m being ripped off...
Viperholics,
O.K. I don't mind paying a little more for Viper parts. But $18 bucks a peice for little washer/shims??? And I need 4 of them. I am re-installing my factory 3-point seat belts, which were removed by the previous owner. When I removed the center/rear bulkhead, I noticed the 4 bolts/4 shims that are need to mount the 2 belt retractors were missing. The bolts are $2.50 each (not too bad), part #6034383. The washer/shims are part #4708494. $18 a peice. Crazy. Nearly $80 bucks for 4 washers after tax. Can anyone give me advice on the dimensions or alternative washers I can purchase at the hardware store, for probably .35 cents each? The picture shows the washer/shim under the seat belt retractor in the upper/left corner of the picture.
P.S. - I already tried both part masters, Jon B. and Chuck T. They only have access to the overpriced $18 washers.
P.S.S. - I know it's only $80 bucks, but for 4 washers? I just can't bend over that far. Sorry DC, no noockie for you...
Viperholics,
