Edward 96GTS
...every went well except the hood will not close. It seems that the top portion on the front fascia where it meets the leading edge of the hood is very tight w/ bra on( the bra material/Straps are being pinched).I'm avoiding using excessive force to close hood. Anybody else have this problem? At this time I have not tried to install the hood portion of the cover because it would make the hood even tighter. Note: the back of the bra has a mesh applied in the grill opening and fog light areas that is coarse nylon material. It may cause clear coat damage, so I applied clear shelfing material to protect the paint. The shelfing material can be purchased at any hardware store, think of it as a removable 3M clear protectant.
TIA
TIA
