01sapphirebob
I am storing my RT/10 this year to drive my ACR and the question is in the headding. I do plan to drive the car once a month just to keep everything on the up and up. Any thoughts would be great!!
Gasoline is not a single type of molecule, it has a distillation curve. Some of it evaporates at 200F, some not till 300F. This determines how well the engine starts (enough gasoline has to turn from liquid to vapor at low ambient temperatures) and runs when warmed up (to prevent boiling in a fuel line which prevents the pump from supplying the engine.)
In time, the lighter ends evaporate. After storing your lawnmower over the winter with a vented carburetor, it will be hard to start - not because it has gummed up the little carburetor, but because not enough of the old fuel is turning from a liquid into a vapor. Also, every time the system heats and cools, it pulls air into the bowl and adds moisture.
Your Viper is different. The tank is not vented (except through the charcoal canister.) It won't accumulate water over a winter. It can handle low volatility fuel because the fuel injector sprays a fine mist no matter what.
Fuel storage additives are anti-oxidants and prevent the gummy deposits. However, the oil companies are required to add these types of additives so a one-year or two-year storage period (in a closed container) is going to be OK. The hard-to-start issue is mostly due to the partial evaporation leaving the large, hard to burn molecules behind.
PS If you live north of Texas, here is an idealized explanation of how to maintain your snow blower. At the end of the snow season, keep the fuel tank low. After using each time, run the carburetor dry. Buy fuel in late fall to refill. This should put mostly new, easy-to-evaporate fuel in the carburetor for the new season. The worst thing upon first snowfall is to be yanking on the cord, fiddling with the choke and mixture richness, wetting the spark plug, and then puking the black cloud... all because the carburetor isn't "tuned" to the aged, low volatility fuel.
Tom, one other thing... What do you think about this ZMAX product that Carroll Shelley is promoting as an addition to your engine oil where it "penetrates the metal"? Just Hype? Any opinion?
