how to remove clutch able out from tranny??
venomblue550
for some reason, the clutch cable end goes into the tranny itself...it will not come out....the fitting will move around, but just not coming out....???
Jack B
NE Ohio
That is a quick connect fitting, push the white tabs toward the trans. The best tool is one which looks like a "U".
V
venomblue550
that's what i thought...let me go try again..thanks for the info...
GR8_ASP
Plus it is not a cable. It is a hydraulic hose with a quick connect fitting.
Jack B
NE Ohio
It helps if you push the hose towards the trans, this relieves some of the force that engages the quick connect.
Kkustelski
