I couldn't take it anymore (water leaks, etc)
SlowCreamPuff
Bellevue, WA USA
I couldn\'t take it anymore (water leaks, etc)
I took it to a Dodge dealership based on recommendation from local club members.
Results: Fantastic!! Cam, the Viper tech., is great. Water leaks and hood rubbing on the headlight lenses are now fixed. Haven't had a chance to test the oil consumption fix, but I feel pretty confident that it's also fixed.
I was wrong... Dealership repair doesn't equal bad news.
So, if you are in WA and needs our Viper worked on, I highly recommend Cam at Monroe Dodge.
SlowCreamPuff
Bellevue, WA USA
Re: I couldn\'t take it anymore (water leaks, etc)
I don't know all the details on the oil consumption fix. There is some kind of "baffle" in the valve covers. Under hard braking, oil was getting to the intake side. By sealing the "baffle" in the valve covers properly, it's supposed to fix the problem. That's as much as I know...
Some expert on here can probably elaborate or correct...
Joseph Houss
NJ USA
See Mike! You can get some use out of that 3/36 warranty! Glad to hear all is fixed!
H8TOW8
I too use Cam at Dodge of Monroe - he is the best "car guy" I have ever dealt with!
ViperGear
