I want the Air Box Engineer-arghhh!!!
Tomer
Los Altos, CA
OK, I installed my Snake Oyl smooooth tubes and K&Ns tonight.
What should have been 30-40 minutes of joy turned into >60 minutes of frustration...I am still not sure I should drive my snake!!! (96 RT)
First off, the Snake Oyl tubes don't have a visible cut (angle) on one end of the tubes, but they fit OK...The instructions were pathetic, although I know this should be an easy job...
The BIG problem is the STUPID clips on the air box. I found I had to remove the air box to even come close to installing my K&Ns...I noticed I was missing at least one clip when I removed it...Now with the K&Ns, I had those STUPID clips jumping off the air box like gr****oppers...I would install the clip, then clamp it down, then a second or two later, BING, away it goes a good 4-5 feet....Whats with this...Its soooo frustrating!!!!
Are there longer clips available? I believe the issue is in the difference in density (compressability) between the rubber gasket on the stock air filters and the K&Ns...Also, the air box seems a little warped, and combine the two and those stupid clips (did I mention I hate them) just FLY off....
So now, on the driver's side I have 3 of 4 clips, and on the passenger side i have only TWO clips installed...
I am afraid with normal driving and bumps in the road, these stupid (there I go again) clips will fly off...
Help!!
Tomer
(trying to calm down...I hate it when the simplest things get you down....)
PS I don't have any more clips...Boy do I need clips!!
T
Tomer
Los Altos, CA
Oh yah, as of tonight my car it *******, and with the weather being great here I just HAVE to take her to work...But I am worried about the pass side air filter where I only have 2 clips installed...
Tomer
PS Don't get me going on those clips again!!!
Ulysses
San Diego, CA. USA
Tomer,
Don't drive with it that way. All of the earlier Vipers needed to have a part of the airbox modified (read grinded down) to get K&N's to fit or the clips would pop off.
May not apply to you, though, since you have a '96. Don't know, maybe someone wiser will speak up here.
READ ALL ABOUT IT HERE
FirecatF7
