Install/Mounting AEM
mbccenter
Legacy Supporting Vendor
Forest Lake, MN
Drivers side on top half under the windshield cowl. Just used some 3m lock so can remove easy. Did you get everything worked out?
Simms
Pittsburgh, PA
The ECU is mounted where my stock ECU was, and the injector driver box is right on top of toe box.
The factory ECU was relocated to the passenger side under my dash I believe (never actually looked for it)
mbccenter
Forest Lake, MN
That is how you do it on a gen 2 but this is a gen 3:lmao:
britospeed
The painted panel comes off with 3 torx screws without removing the side sill.
FirecatF7
