Thanks to all, no they do not make them in 18 in., I only have them in the rear, yes rocks do stick to them and you hear that awful sound of them hitting your wheel well, and I never dragged the car before so I could not tell you with stock tires. MES I launched at around 3000 rpm with a dry burnout first had a little spin and then it took right off, and my best 60' wa with 22 psi but then again it was only about 50 degrees out so the pavement was cold I dropped to 20 psi then the good ol clutch gave out it started to slip so I called it a day after 4 passes all in the 11.9's best being 11.91 at 118.3 that was with S&B filters smooth tubes and roe's VEC1, now i am waiting for headers, exhaust highflow cats and flywheel and kevlar clutch, I will see the track in about 3 weeks with these mods.
