The car was a 97 with a Hurst Line Lock. The following miscellaneous materials were needed:
Summit line-lock tubing kit (use two 12" tubes)
(1) extra 1/8 pipe 90/elbow x 3/16 tube
(2) extra 1/8" pipe plugs
(1) momentary mushroom switch from Summit
Tubing bender
Mity Vac for bleeding
I also found it easier to switch the ground with the mushroom switch and pick up the positive 12V next to the PCM. Also be careful to distinguish between the pipe fittings and the flare fittings. Use the teflon tape on the pipe fittings, however, start the tape a couple threads up from the bottom.
A 3/8" shorty wrench makes it easier to access the proportioning valve.
Tubing bender
