line locks???
STUGOTS
NY/CT
anyone have them or know where to get them??
Who has the best ones and how much do they run?
Also how many hours of labor to install?
Doug
pearland,tx
check out jegs or summit racing. Hurst makes one. jegs pt# 530-174-5000 $109.99 installation kit 29.99
STUGOTS
NY/CT
Thanks for the part # and this one fits fine on a viper?
IEATVETS
Cottage Grove, Wis.
I got mine from Jegs. Cannot remember the cost but man is it fun!! I think it took around 2-3 hours to install. Great for doing burnouts and flooding intersection's with tire smoke. :headbang: :D
STUGOTS
NY/CT
can one of you guys who know about these check out part # BMM-46076 at summit for me and let me know if that will work?
Doug
pearland,tx
I'm pretty sure it will work. They all work the same, it just different name brands. It depends on how much you want to spend. All you do is splice the unit in your front brake lines hook up the wires and your ready to burn your tires after you bleed your brake lines.
Joseph Dell
Atlanta, GA 30338
do yourself a favor, though... the switch that comes with the hurt or the summit setup is poor. replace it. i didn't listen to that advice and found myself in the burnout box with the tires not locking all the way... you roll so you have to stop, back up, and try again. a new switch fixes that.
good luck!
BTW - do a search on lineloc on the board here. i forget who posted it, but there are some pics that are so good that you won't need to read the instruction manual...
JD
STUGOTS
NY/CT
stu u planning on tracking the car this summer??
maybe a track day or 2 this summer but mostly its for the streets, dead stop at a light need tome grip.
jp
Umea, Sweden.
The Hurst is the one to choose. Some of the cheap ones tend to burn if they are engaged to long.
GenV
