RockyTop
Back hatch requires no battery. Open it, reach in and trip the emergency (i.e., mechanical not elctrical) lever on the inner door post on either door to open the door. Hood should also open with no battery needed. Hook up a Battery Tender (T.M.) to the battery post there (covered by red plastic cover) and hook the negative to the small screw on upper surface of sidesill just below and to the left of the battery post. Using a battery tender should allow you to avoid this all too common occurrence.
