Looking for an engine pic with catch can
KNG SNKE
Portsmouth, Rhode Island
I am trying to figure out where to put these catch cans that IEATVETS sent me for nothing (thank you very much) and I am having problems finding the post pictures of your engine bay thread. The search engine on this web site really blows and it is not returning the forum I am looking for. I am looking for a gen 2 setup that has 2 catch cans installed. For the life of me I cannot find a spot on the motor that will allow me to have them both in the same symmetrical region.
treesnake
St.L
[media]http://gallery.viperclub.org/data/500/Home_finally_007.jpg[/media]
You can see the catch can breathers on the outside of each smooth tube.
I'll post some more photos when I get back to pc.
Dom426h
DE
I put mine in place of the useless windshieldcleanerfluid reservoir.
K
KNG SNKE
Just took a close look at your setup, you have a different radiator hose. Also how in the world did you get your hood hinges shiny? Did you remove them? I am not going to do it but I am curious. I see your mounting spot and I am able to utilize the same spot though I dont have a bracket on mine. Where did you get those stantions to keep them elevated and did you bolt all the way through the cross support.
ViperTony
Hopefully this helps. http://forums.viperclub.org/illustrated-upgrades/641305-my-genii-ccv-air-oil-seperator.html I mounted my seperator on the crossmember using this bracket with rivet nuts:
Red Snake
NashVegas
I'm only using one can. You can see where it's mounted in the pic below. Not sure how yours mounts up but mine came from JMB Performance with the tab made into the can.
Toby52
