Loose exhaust cover on my GTS?
KDR83
Tampa, FL
The passenger exhaust sill is a lot more loose than the driver side, where are the attachment points so I can see if one of the bolts came off or what the deal may be? It's not the two at the top front, it's loose towards the rear by the rear tire.
Indy
Vancouver
Under the door sill....there are 4 covered by plastic taps when you open the door. Also underneath the rockerpanels you will find about 6 or so screws which are the same ones as used at the top.
Kkustelski
