lowering springs
bluesrt
any trick to the trade on assembly of eibach lower springs on a srt10 coupe
RobZilla
Jacksonville, FL USA
Much much much easier if you find a local shop to do the spring/shock swap. PITA to do yourself.
Just bring the assembly to them and it's really cheap and only takes a few minutes. Be sure to adjust the shock compression before they put the coilover back on.
:usa:
B
bluesrt
i have a lift and spring compressor,just wondering wich a-arm is easier to lift as alldata does not tell you- i can figure it out but if anybody has allready been there,i wanted to steal a tip--thanks
AbsolutHank
Odenton, MD
Which A-arm? You don't need to remove/reposition any A-arm for installation. The fronts need the sway bar to be disconnected from the lower control arm. In the rear, just remove the rear-most wheelhouse liner, and then the little circular shaped plug (5" diameter) and the complete coilover comes out. I wouldn't, and didn't, mess with any controls arms on mine
FirecatF7
