I don't recall what the capacity is on the MPP pan. It may not have the higher capacity of the 2000+ pans. Jon B. was going to measure the stock 96-99 pan, the MPP pan, and the 2000 pan.
There are less expensive options than the MPP pan.
Both Joe Dozzo and K&P make baffle kits. Dozzo baffle is like the MPP (CDI) baffle design So put them and a 2000 windage in your 96-99 pan and it's pretty close to MPP.
I got the 2000 pan, windage, & Gasket from Jon @ PartsRack for great price. He now has the full kit of the above plus Dozzo's baffles.
Some basic info below. The Pics on the North Texas Site are Dozzo Baffles from PartsRack:
http://vca1.viperclub.org/ubb/Forum14/HTML/008712.html
http://vca1.viperclub.org/ubb/Forum14/HTML/011156.html
http://www.northtexasviperclub.com/2000oilpan.htm
2000 Oil Pan: Some of the internal casting CLEARLY shows Dodge is thinking about baffle systems. There are 4 cast bosses that look purpose-cast for this purpose - that is inner side is cast flat on the castings so that baffles will lay nearly flush when in the "closed" position. While most people don't talk about the windage tray, it really should be considered as part of the "package". The 2000 windage tray is a BIG improvement over the 96-99 tray and at about $60, IS worth obtaining - will work like a charm in a 97 GTS with either your existing or a 2000 pan.
2. Any pan with baffles (and all the 96-99 Gen II and 2000+ will take them with very little work) is better than without. The baffles Joe Dozzo has for the 2000+ pans are very simple to install An optional thing to do, in addition to installing the baffles, is semi-polish the inside of the pan. Viper pans, new and old, are very rough on the inside. The OUTSIDE of the pans have a slightly better finish than the insides! It's work an hour or so of time ($50) to smoothe the inside of the pan to promote oil return, rather than clinging to the rough cast finish. Does not need to be a mirror surface and some of the corners are very difficult to get, but I feel it's an hour+ very well spent.
3. Modify your 99-99 pan. This is the price performance winner if you have a 96-99. The baffles for the 96-99 Gen II pan are a bit easier to make and cost less than a 2000. I'd very definitely recommend a 2000 windage tray. (Note, Joe will provide a template showing where to add the additional drain holes at nocharge for those who've been buying the baffle kits to install themselves.)
4. I don't have a recent price for the MPP pan, maybe $1200? Yes, It is all factory parts, including baffles, but at a price and you still need a windage tray and might want to to clean out the inside! In summary...
1. 2000 Pan + Windage Tray ~ $500 assuming VCA discounts.
2. 2000 Pan + Tray + Baffles + "semi-polish" ~ $725 - $775.
3. 1997 pan + Tray + Baffles + "semi-polish" ~ $200 - $300.
4. ACR Pan + Tray + "semi-polish" ~ $1200+
Just buying a 2000 pan (and tray) does little to improve the oiling system, leaving choices 2 - 4, all of which, in my opinion, are roughly equal improvements in oiling system performance.
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by Marv S on 09-22-2002 at 11:00 PM</font>
