more newbie questions about a GTS
MoparMan
Las Vegas, NV
I'm seriously considering a black/silver '00 GTS but have a couple of simple questions:
1) the knob under the dash for the pedal adjustment is missing - this is a simple part for a dealer to get, right?
2) should there be a bulb pump to adjust the air bladder in the seats on both the driver's and passenger's side?
3) where the soft upholstry attaches to the door frame on the driver's side there is a small crack at one of the screw heads - looks like someone hit it getting into the car - is this typical wear?
Thanks for your help.
Anthony - 98 GTS
Houston, Texas
Answer:
1. Pedal adjustment knob is a relatively cheap replacement part, order from Chuck Tator.
2. Pumps are on both driver's and passenger's seats.
3. Not un-typical wear. Piece usually gets nicked/damaged either from getting in and out or from the seat belt.
