Motor Mount Torque Specs
70cuda
Is there a recommended torque spec for the woodhouse motor mounts and or trans mount. Digging into it tonight so wanted to find out first since the mounts did not come with instructions. Thanks, Tyler
BAD BOYZZ GARAGE
Sacramento
Double Check your manual & with MJ from Woodhouse. Here is stock specs:
Trans Mount Bolts - 30Ft.Lbs.
Trans Crossmember Bolts - 45Ft. Lbs.
Bolts, Engine Mount Bracket to Block - 30Ft. Lbs.
Nuts, Engine Mount Insulators - 75Ft. Lbs.
Hope this helps.
Toddy
70cuda
Thanks for the info, I just did them up tight, (was already done by the time i saw your post) The torque wrench never saw the light of day but I just tightened the nuts up with the bracket in the bench vise to the point that they were real snug, as in you'd have to really lean into it to get them much tighter. Hope there isn't a specific procedure that I missed as I don't think I'll be taking them back out. Thanks again, Tyler
oldvenom
