My Snake is Losing its Skin!!!!
JohnnyViper
Massachusetts
Hi everyone, I have a 97 GTS and my door skins are separating a bit from the inner door. If you open the door the side that faces out, if you look at the top you can see that it is starting to separate...has anyone experienced this and if so what did you do about it. Thanks in advance –Johnny
cratica
austin,tx
yep, on my passenger side (97 GTS red as well). Driver side is fine. One of these days I'll take it apart and fix whatever it is that is causing it to stick out.
Phun70
Urbandale, Iowa
Don't worry, it's just shedding it's skin, that's perfectly normal, it will come out as an 08 SRT-10.
Black Moon
Knoxville, TN
Check out 'Lord Fusor' products. They have adhesives for any type of material you want to reattach. It is a caulk gun type product and easy to use. Once it's together it will never ever come apart. I've used on fiberglass and plastic bumpers. Amazing stuff but a bit pricey.
J
JohnnyViper
Massachusetts
oh that would be nice....wake up one day to find my 97 as a 08 :2tu: i wonder if i take it to a body shop they can inject some resin between the inner door and skin the clamp it??? wonder if it would hold?
J
JohnnyViper
Massachusetts
btw looks like my wheels shed already with new skin on them :headbang: blackmoon thanks for the tip i will look into it!
bluesrt
dont you see this? mr take it to the bodyshop and clamp it
J
JohnnyViper
Massachusetts
yes it posted when I was composing the post that followed, which is why I created another post right after thanking blackmoon....didnt you see!!! :dunno: just bustin on you
J
JohnnyViper
Massachusetts
I went to a body shop this weekend, they are going to look into seeing if the viper needs special seem sealer and if there is any service bulletins on defects with the skins
J
JohnnyViper
Massachusetts
seriously dave666 please don't post just to correct a spelling error....you know you have made them as well, only relevant information to my problem please!!!....dave is this how you massed 13,000 postings??? :dunno:
sham5430
