Well, with some work, I fitted the Gen II hood from my B&W GTS (Bburago) to my UnMcViper. And, today I received my '96 RT to give me the correct chrome gen II wheels.
With some grinding and cutting, I've fitted the Bburago hood to the Maisto RT body (see pics). Now, I need to sand and paint and I'll have an RT/10 as close to my '98 as possible.
Had to grind down "locking bumps" on RT that hold the hood closed:
Had to cut the hinge piece and grind down the inside edge of each bottom where it meets the RT body:
Then, the correct chrome wheels came today, so here it is minus some finishing work and correct paint Yes, oops on the scratch at the edge of the hood above the headlight...but I will fix before painting:
Getting closer, though I kind of like the black wheels (put on the silver 96 I received today.
There are clearly some size differences between the hood on a Bburago and that of a Maisto, though it might be the difference between a GTS hood and RT/10...not sure.
Next post I should be done......hopefully.
Peter
Peter
