Need a computer for 96 GTS
v96gts
Bavaria,Germany
I had a problem last year with my stock 96 GTS enine. With warm engine on a traffic light and a/c on idle went down as low as 300 rpm , tended to stall, but came back again and idled normal(worse with lights on).During winter i swapped into a 98 engine , with heads , cam,.... .Runs perfect , but still the same problem.Yesterday i installed my Roe S/C (8psi) ,car runs good(only made a short test drive yet),but exactly the same thing:stopping reduces idle very much,with S/C and a/c on it even quits.But everything has changed since last year-except stock computer and intake temperature sender.Batterie is new.After checking with a scan tool there is no trouble code ,O2 sensor voltage is good,everything seems to be perfect. I don´t think it is the temperature sender,so i`d like to try a different computer.I`m going to buy a new one, if mine is not working properly - but at first i`d like to try a used one , to be sure it is ( or is not) the computer.So if anybody has a known good 96 GTS Computer he wants to sell, please let me know.
Peter
Leonard Knight
Glendora, Ca. USA
You might check the IAC motor on the side of the right throttle body. I had the same problem and it turned out this was bad. They also get dirty and can have the same effect. Try cleaning it first before the computer.
erikguilefuss
