I am looking to get as much information from those who
are running 1/4 mile runs.
1) TIMES SLIPS
2) GEAR AT THE TRAP - 3RD OR 4TH
3) TIRE PRESSURES
4) TRACK TEMP & AIR TEMP, PLUS HUMIDITY
5) ELEVATION - HOW FARE ABOVE SEA LEVEL
6) DID YOU HEAT YOUR TIRES ( BURNOUT )
7) HOW DID YOU SHIFT ( POWER OR GRANNY )
8) RPMS AT LAUNCH
9) SHIFT POINTS ( RPMS AT EACH SHIFT )
10) ANYTHING AND EVERYTHING YOU CAN TELL ME
ABOUT YOUR RUN.
*** ALL INFO VERY MUCH APPRECIATED***
TOM ( WANTED )
1) TIMES SLIPS
3) TIRE PRESSURES
8) RPMS AT LAUNCH
ABOUT YOUR RUN.
TOM ( WANTED )
