Need Line lock installation pics/tips (JackB)
Simms
Pittsburgh, PA
Anyone have any good pics or advise to installing one? I bought the Hurst kit and I know JackB had some pics at one time but I can't see them anymore.
IEATVETS
Cottage Grove, Wis.
I will post pics of mine later tonight for ya. I didn't install mine so I can't help you with the installation part of it but the pics will show you how mine is installed. :D
Jack B
NE Ohio
Here is one of five pictures that are contained in "My Gallery" under Jack B
Go Fast For Life
Here is my installation.
RSNAKE
Pittsburgh, PA USA
Has anyone ever had a line lock malfunction on them. Let go when it was not supposed to or turn on when it was not supposed to?
Joseph Dell
Atlanta, GA 30338
Sometimes, my lineloc (even though it is engaged) won't hold the front tires. When this happens, I back up and try the burnout again. not quite sure why this is the case, though... mine has always been like that.
JD
CHAD
Sarasota, FL
Joe, make sure you have plenty of pedal pressure before you press the line lock, ie push ******* the brake pedal before engaging the button.
There is lots to do at the beginning of a run and this is sometimes overlooked. If your car brakes well, it has more than enough front brake power to keep the car still for a burnout.
Chad
