To make up the difference between the RT cats and the header pipe, I had a engineered collar/sleeve made. It was then welded into place. Didn't slot the cat ends or use clamp bands.
The outboard sections did just hang there, check after a couple of days of use check that there is no slack in the header bolts and re-tighten
