New exhaust is on! woohoo!
MadMaxx
Simpsonville, SC
Yay! my first installment of low-buck mopar muscle is done. Went from old crusty stock exhaust to new crusty exhaust with some attitude
Replaced stock cats w/ 2 1/2" strait pipe (savings of about 20lbs right there atleast!), and a rear muffler delete w/ 2" crossover pipe. Sound? Like a pissedoff hornett with a chainsaw
Nah, it actualy sounds quite good, a crossover tubed (aka H pipe, or X pipe if you want to fab one up) helps ballence the load between the two banks much better.
-Cat delete sections are 2 2 1/2" pipe 22" long. Cost 10$
-Muffler delete consists of 2 2 1/2" pipe sections ~16" long (cut just in front of the stock muffler, and about an inch past the tip welds) and 1 section of 2" pipe. Total cost for this section 8$
Total cost: 20$
This is not counting the air tools I used in the R&R, or the welding equipment.
still have a small leak on the drivers side bank, where the first weld was cut. I'll fix this tomorrow, but overall very sound. Weighs ~30lbs less than stock i'd say, and still 70lb lighter than a SS system.
The only thing that ***** is that dodge's section of pipe that comes off the manifold and curves around to meet the cat (welded) is not a true 2 1/2 section, it's smaller somehow. a 2 1/2 flared end will make a larger gap than one would like, creating the point of leakage. The rest of the system goes together tight, and very solid metal-on-metal contact.
I tapered the end of the 2 1/2 flare to make the contact better on the inlet side of where the cat used to be. A good hit with the mig welder should make everything work out. Like I said above, I had a minute leak that i'll fix in the morning.
I would recomend a ballance tube to people, even w/ stock or replacment mufflers. Seems to help a bunch. Anyone tried a X-pipe yet?
So, for 20 bucks and some good old fashion bonding with my car, I've got a much louder system that should flow a bit better. If I ever decide to play nice by EPA standards, i'll throw a high-flow cat back on, but I doubt it
MM
DEVILDOG
VCA Member North TX
VENOMVILLE, TEXAS, USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by MadMaxx:
Move to SC... no vehicle inspection of ANY kind. got to love it
MM
<HR></BLOCKQUOTE>
MM,
It's my understanding that there is no vehicle inspection in SC because if they had one there would be no SC vehicles on the road and all the gas stations would have to close, thereby, causing great inconvenience to all other out of state vehicles passing through SC that need gas. I believe that years ago the Jimmy Carter administration issued an Executive Order to SC to not have vehicle inspections for that reason.
Enjoy your new sound!!!
Snake Bitten
Southern Kalifornia
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by riotac:
I cannot cut my cats since I have to go thru emissions inspection every other year ( and they also physically look to ensure the cats are present)!<HR></BLOCKQUOTE>
You can remove the factory cats and install 3" high flow cats...you WILL NOT BELIEVE how cool your sills will run, and it will add to the sweet Corsa notes...
M
MadMaxx
Simpsonville, SC
Yep, high-flows are the way to go if you have emmissions to worry about. Stock ANYTHING as for as exhaust goes is no good. My sills run almost warmnow, and cool off VERY fast after the engine is off. stock cats trap soooo much heat
MM
sham5430
