Octane Boost??
Bonkers
DelaWhere? USA
The additives are already in the gas you buy at the pump. Additives don't do anything for the fuel system despite advertising but they don't hurt anything either.
If it makes you feel better then by all means go for it.
You'll need to refill the entire tank with higher-grade gas to actually raise the octane level of the juice flowing to the engine. One little bottle of any additive changes nothing with the gallons already in the tank. Raising octane levels is not that easy.
Don Hiltz
Rainbow City, Alabama
Unless you're experiencing detonation or preignition knocking, why would you want to use an octane booster? Remember: If it ain't broke, don't fix it!!
Greg D
Actually, an increase in octane may eliminate detonation, but not preignition.
Detonation is caused by combustion pressures that develop so fast that the heat and pressure will "explode" the remaining unburned fuel. A knock or ping results from the violent explosion when the normal flame front runs into the secondary flame front. Detonation can be caused by lean fuel mixture,
fuel octane too low, improper ignition timing, lugging and
Excessive milling of heads or block (which increases compression ratio).
Pre-ignition, as the term suggests, is the ignition of the fuel-air mixture before the regular ignition spark from the spark plug.
Pre-ignition can be caused by carbon deposits that remain incandescent, spark plugs too hot a heat range, sharp edges in combustion chamber, valves operating at higher than normal temperature because of excessive guide clearance or improper seal with valve seats, overheating and ignition crossfiring from induced voltage in spark plug wires that run parallel to each other for long distances.
The only octane boosters that have worked for me are the ones with the ingredient MMT which acts as a lead substitute and slows down the combustion process preventing detonation.
In closing, if you have enough octane to prevent detonation,
you don't need more. Octane alone doesn't make horsepower.
ndvipergtsr
fargo, nd
I have used two differant octain booster which worked very well for eliminating detonation (vp race c-5 and nos brand racing formula) which contains a small amount of nitro methane, I ran these in my ford lightning with higher boost levels on 93 would detonate above 4500rpm with them i had no noticable detonation. Jerry
