Painting calipers
wikkid
Would really like to paint my Gen 3 calipers red. Can someone point me in the right direction. I have looked up threads, but cant seem to find the info or directions on how to do it.
dave6666
Short of the kits like you buy at Auto Zone etc, I think the other end of the spectrum is really the better deal try R&J Distributing they disassemble them and powdercoat them. That would be the most correct way but costs way more than rattlecan. Also try Eastwood they may have something in the middle.
plumcrazy
ALL OVER
might wanna talk to tom about this. i think he might be able to help.
the caliper has to be totally disassembled before powdercoating it
Black Moon
Knoxville, TN
I've used the spray cans on several cars with excellent results. Just tape off what you don't want painted. Clean with brake cleaner then lacquar thinner. Apply several light coats so they don't run. Good luck. If you pull them off the rotar and remove the pads you'll have better results.:)
AZTVR
Chandler AZ
VHT caliper paint sold at Autozone does a decent job. I've only tried it in black, though.
dipapa
San Jose, CA
I had my calipers proffesionally sprayed copperhead, with black viper stickers then clearcoated. now they perfectly match the copperhead and black color scheme on my car with a finish as good as the body paint. A&C Performance took care of all this. Calipers looks great. The entire caliper, fittings, tubes, front and back were done.
They deterred me from powdercoated because then the entire caliper assembly would have to be stripped down and seals cannot go into the oven, then it only make sense to use new seals on re assembly. Too much labor and parts costs.
I guess if copperhead was available in high heat spray can I may have saved money and just done that, however they are real nice now.
W
wikkid
Ted what kind of brush did you use. And what did you clean the caliper with. That looks really good.Did you pop the pads out when you painted? How many coats?
Thanks John
RTTTTed
The calipers were new. Didn't like the 'neutral' color for my Sapphire car so I bought a Duplicolor Caliper paint kit for about $30. Brush and everything needed came in the box. I painted the calipers twice with the brush in the kit. Brakeclean is an excellent cleaner, but my stock powder coated calipers only need a wipe and they're clean.
First coat the calipers looked terrible with big streaks, but the paint flows out so when they're drying they look much better. I painted the second coat the opposite direction. The now have about 25,000 miles on them (with a track day) and they're still like new.
I had no pads in the calipers for the first coat. You could paint them on the car if you wanted, from outside the wheel there's not too much that can be seen. I just like to do "that little bit extra" to make them perfect. Here's what they look like with the wheels on.
Ted
happy
p.e.i canada
i just did mine on my 02 gts now i just got a get teh viper declas for the front calipers. no pics as im away but will put up soem when i get back also used duplicolour i got 3 vehicles out of the one can and i do 4 coats on each caliper start at 1 caliper by the time ya get back to the one ya started at it will be dry for next coat.
sham5430
