Part # 04642581
Paolo Castellano
Elburn, Il, USA
Hello all, I am wondering if anybody knows if the part on the slave cylinder hydraulics that the red anodized part with the cross-cut plastic clip clips into(The black, about 1.25" long and 1/2" in diameter tube that has the sticker 04642581) that attaches to the slave cylinder via a circular metal press-fit pin clip is a separate part? Or do you have to buy a whole new slave cylinder?
I just accidentally broke the ****** fitting at the end just before the ****** goes into the O-ring for the aluminum body that bolts to the transmission.
Any ideas?
Mike Adams
guelph, Ontario, Canada
It only comes with the Slave Cylinder. I just installed one 2 days ago. You should be able to get it pretty quick. If not I have one instock still I believe
Atom
