Hey Guys.... Here's where I am at now...
I measured the fuel pressure today and I got some really interesting results...
No extra fuel is being pumped... It basically hovers at 55 to 60....
Even if I go up to 4500RPM..no extra fuel..... What else is interesting is I am not pinging... Which is really good...Likely because of the Water/**** kit......
I have heard what sounds like and it is not pretty...... So thats a good thing...
So I went to get the trusty multi-meter out to check if the pumps are coming on and sure enough it wouldn't work... Even with a new battery.... Man... Its always something...
So I figured I would give Doug a call to leave a message and sure enough he answered the phone.... Do you believe it..Doug was working on the holiday...True ******** viper tuner.....
Anyway he gave me some things to check like a kinked vacuum lines... Sure enough there were no kinks...I also came to the conclusion that it couldn't be a vacuum problem because the water **** kit is still working... At least I think it is.....
My next thing to check was the FCU... I noticed something very intereting when I opened it up... There is only one spring retainer.....
In the diagrams I have downloaded off of the paxton site it shows 2 no matter what year viper you have......
So I am thinking this is probably causing the issue...
What's also interesting is that this kit was supposed to be off of a 2003 viper...
Interesting because we found something engine pieces in the supercharger when we recieved the kit......
What's really intersting is that no one has ever opened the FCU before..... Because as soon as I twisted one of the bolts it tore the label.... because of where the label was placed.....
So anybody know if this would cause my issue????? I wasn't able to ask Doug about this... I figured he went home and enjoyed some of the holiday..
Thanks for your time....
Joe
