Paxton SC belt/pulley rubbing Question
Art 138
Davie,FL
I noticed considerable belt dust around the Alternator pulley; upon close examination noted that the DLM installed Supercharger pulley nose is abutted tighly against the alternator pulley. I have called DLM to take the car in. Question has anyone had this problem? Is SRT-10 alternator adjustable-thought I might be able to pull it away(down)from the SC pulley.
GR8_ASP
Alternator is not adjustable. DLM uses a unique supercharger bracket than Paxton so I am not up on it. The Paxton kit mentions pulling away from the engine when tightening the supercharger if clearance is too small. Mine was okay without loading.
Viper X
No, alternator is not adjustable.
Yes, my standard issue Paxton setup had the same problem just after installation. My installer loosened everything, put some upward pressure on the supercharger, added loc-tite to all of the fasteners and re-tightened. So far, no further problems in about 4000 miles. This is a very tight fit, my clearance is only about .060, but it seems to be holding.
Good luck.
Dan
