We have done numerous of these installs with great results. With any new product we have noticed a few things that can make this setup work better.
The cars do run hotter, seem to have more chassis flex, and those with headers and no heat shields can run into some heat related electrical issues. Overall I applaude Paxton and their chief engineer Chris Whalley for a job well done.
With a little experimentation we have come up with resolutions to all these things. There are also a few tuning tricks to make the setup more powerful without sacrificing reliabilty.
This kit can be upgraded for more power with some small changes. We really do not like to tune these systems over 750hp because the engine really is not built for it. We have overhauled many a engine in the past and have found the connecting rods are the weakest link. The engineers at DC agree, better to error on the safe side. The cast piston cars do not like more than 6psi but with some head work and fuel system upgrades can make 650rwhp no problem. Add a cam change and at 6psi weve seen 680rwhp. These are not huge numbers but they were made with low boost and long term reliability in mind.
The biggest limitation to this kit to make more power is the fuel system. Just fine for a stocker with headers and rocker arms but anyhting more requires
a injector resize, pump change, and some computer tuning. Real power requires a proper fuel system. Any change from stock requires a little FMU tuning to get the air-fuel correct. If you can data log A/F on the dyno it really helps to get it right.
We soon will be finishing a proper fuel system upgrade that will be track
friendly and will work for open road race events such as the Silver State.
Most the tuners who make big hp warn not to run less than a 1/4 tank or you
may starve for fuel.
With the help of AEM and Paxton we are doing a 14-18psi system with a purpose built engine. We are excited to see the results.
For any of you interested in doing this Paxton setup, I think we have a very good knowledge of this system, we helped develop and prototype it and have learned through experience how to make it work best. We welcome your inquireys and questions. Let us know if we can be of any help.
