Pic inside.. what do you think of this hydraulic coil compressor? Experts please!!
Qualitywires.com
Louisville, KY
Has anyone used something like this on thier viper? It says it will do 3/4 of a ton of pressure on the springs....is that enough pressure to compress the springs? Let me know if this is a piece of junk or not.
thanks
HYDRAULIC COIL SPRING COMPRESSOR
*PARTS*
*Screw 1
*Spring 2
*Nut 1
*Bushing 1
*Sealing Ring 1
*Retaining Ring 1
*Piston Rod 1
*Cylinder 1
*Cylinder Screw 1
*Connection Nut 1
*Washers 4
*Lock Washers 4
*Bolt M16*40 4
*O-Rings 2
*Coil Bracket Base 1
*Coil Bracket 4
*Hand Pump 1
Capacity: 0.75 Ton
Stroke: 110 MM
Mike Brunton
N. Andover, MA
AB,
The capacity of it will be enough to compress the Viper springs...3/4 ton is around 1,600lbs, which is much higher than the higest spring rates you'll find on a Viper (which top out around 1,000lbs maybe).
The only thing I would suggest is get one with some sort of protective surround. If you've never seen a 600-1,000lb spring come out of a spring compressor, well it can be ugly and can kill you.
They make models which have a couple of bars to prevent the spring from snapping out - I'd go with that.
If you are not concerned about that issue, then this one will be more than adequate to remove your shocks/springs.
Q
Qualitywires.com
Louisville, KY
Thanks Mike!! I think this one has the safety feature. I was using a cheap screw type and it popped out on me..so I said to myself..enough of that crap!..Scared the hell out of me.
Thanks!
dansauto
gillett, pa, usa
Chuck is correct get the branick. It is the one that 99% of garages use. It is the safest and easist to use. But why are you buying one? It does not cost much to take the spring to a shop and have them change it for you.
Q
Qualitywires.com
Louisville, KY
Yup, I looked at the Bransnick model. It ran about $400-500 buckaroo's. I wouldn't be changing my springs that much to justify the money. The shops around here charged me $60.00 to remove the springs from the shocks.(This is after I took them off the car myself. I thought that was a bit steep. I figured this would be a nice tool to have around in case I ever need to take springs off again.
Andrew169
