Anyone got a pic of a stock Gen 1 knob on a SVS shifter with the 2" lower bolt? I just measured it and it looks as though half of the knob would down below the console surface.
If you go to the bottom of the page there's a picture of a Gen 2 with a stock shifter handle on a 1" lower shift arm bolt into an SVS short ratio shifter.
The 2" lower bolt will put the bottom of the stock handle leather below the console surface.
The lower the handle is the less leverage you have. The 2" might make it to low for you? The 2" seems to be better with lowering the stock handle with the leather cue ball on top.
