Preventative Trouble Devices...opinions?
Cape Coral, FL
Just wondering if anyone has any input on the following products:
1. Oil Accumulator/pre-oiler
2. Tire pressure Monitor-(internally mounted type)
3. Fan continuation timer and control
Let me know if you have any experiences with them, and the good/bad...
Considering adding the above immediatly upon delivery.
MichaelP
Orlando FL and Seneca Lake NY
What if you car sits at the most 2 days without driving. Is a preluber neccessary? My oil pressure gets up over 40 within 5 to 6 seconds.
Opinion and suggestions appreciated.
Ron
Indianapolis
<FONT face="Comic Sans MS">I can only speak authoritively on the tire pressure monitoring system as that's what I have installed. Works great, is accurate and gives peace of mind especially at speed when the road surface changes and gives you pause.
</FONT f>
Bad_Byte
Corpus Christi Tx
I've had the pre-luber from Sean Roe installed for about two months now. I would do it again and am thinking of doing it for my boat and truck (which sit a lot more than the Viper). It's nice to see the oil pressure come up prior to starting. I have mine installed so its wired to the switch and turns on and off when I turn the key on and off or I can control it manually with the switch.
I have to say its worth the investment to me. Sean is a great guy to do business with as well so that makes it even better.
Looking at JMcGuire's post I think I best be getting that fan kit as well. I am a believer in an ounce of prevention....
MichaelP
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Ron:
</FONT f>
<HR></BLOCKQUOTE>
Thank for the info. Where did you get your system?
oldvenom
