Problem after SC installation. Please help!!
Viper Wizard
South Salem, NY USA
Wie gehts Alex,
The coils should be: Right to Left Upper 10,8,6,4,2 Lower 9,7,5,3,1
If that does not fix it, try to program the VECII with a different card.
I've installed six SC so far and one of them misfired until I re-programed the VEC. I'm sure Sean will chime in here soon, he's the expert!
Maybe this has helped?
Viel Gluck!
LTHL VPR
Aco-
Try starting your car without the VEC2. That will not hurt anything if your car is just idling. If it idles fine, then it may be the VEC-2. If the poor idle persists, then reconnect every spark splug wire, and check every connection (MAP sensor), IAC motor, etc.. that was disconnected when you installed the blower in place of the intake.
Hoep this helps!
-Wayne
LTHL VPR
It may be something related to the injectors or the connections too. Check to make sure every injector is properly connected and well seated in the fuel rails.
Sean Roe
Jacksonville, FL
I sent Alex an e-mail. But, just so everybody knows, the shop manual diagram is incorrect (at least in my 1996 and newer books). From right to left:
Top =9-5-3-7-1
Bottom=8-10-2-4-6
His are connected incorrectly.
The numbers are also on the coil.
Regards,
Sean
V
Viper Wizard
South Salem, NY USA
OOPS! Sean is right! The Service Manual is wrong 96 & up. [Sec. 8d & 8i]
The 96 I have in my shop reads:
Top:9-5-3-7-1 [RT/LT]
Bottom:8-10-2-4-6 [RT/LT]
ViperGTS
>>>Supercharged is NOT equal Turbo <<<
Of course! :D
Mattimous
