PhoenixGTS
My car rode a bit lower on the driver's rear than the passenger rear so I decided to swap the rear shock/spring assemblies to see if it had any effect. Clovis were a little hard to get off, but dis-assembly was straightforward. Now I am trying to re-install and even though they are Eibach lowering springs, the whole assembly is about a half inch too long to get the second bolt in. Big problem is that the control arma will not droop anymore. What the heck is keeping the suspension from drooping a bit more so I can get these shocks in? The service manual does not indicate there should be any problem. Suggestions? The one clovis is too tight together which is making it difficult to get on, but that is another issue. Should have left it alone.
