Paul S Lacey
Well I am now running on PS2's so its goodbye to the runflats and the difference is amazing, less wheel hop car takes potholes better and the ride is much more comfortable.
The rear 19's were almost impossible to buy in the UK so the question is with the pressure monitoring valves has anyone ever had a flat and use the slime and a compressor??
Having had a look at the valves it does not seem easy to fill the tyre
or can standard valve be used with a reflash of the ECU to stop the low tyre message
