Question on rear brakes
Viper Fever
Pocatello,Idaho,83201 U.S.A.
Put on my EBC green stuff brakes today fronts went on no sweat,
the back brakes are giving me trouble.I cant seem to get the piston down far enough to let the new brakes slid over the disc.Ive bled it down ten times my question is does the emergancy brake have anything to do with why Im having trouble ,theres a spring loaded arm on the back of the caliper any tips or help thanks carl-----------------
Sean Roe
Jacksonville, FL
The rear pistons don't push in like the fronts. See the two small holes on the face of the piston? Take a pair of needle nose pliers and use them to screw the piston back in, clockwise with slight pressure.
V
Viper Fever
Hey thanks Ill go try that thanks for the replys
V
Viper Fever
Yep son-of-a-gun the back pistons they twist right in
So finished up cleaned all the brake dust off ,changed the oil,and was lookin real hard at the stock exhaust doesn't look to tough (Corsa thats next)
ViperGear
