Quick Torque Spec Please...
Cape Coral, FL
Anyone with a Maint. Manual, when you get the chance, can you grab the Torque Spec on the lower control arm bolts? (the bolts used for adjustment/alignment, 2 bolts per lower control arm, connect arm to frame)
Thanks!
Cape Coral, FL
Thanks Chuck!
You dont happen to have the upper arm bolt torque and the shock bolt torque too, do you?
PS- Any secrets on these to lubing ball joints, or same as any other car...? Standard grease OK?
95Viper
Phoenix
I use Mobil1 synthetic grease (it's pink) because it was the only one that matched the label in the book that certifies it.
Lube locations at all 4 wheels. Tie rod ends just fill until it squeezes out but be careful about ball joints. Fill until you see boot start to swell. Don't blow out seal.
