QuickJack 7000TL
maverickagm
New Westminster
For those wondering, the quickjack 7000TL works on a Gen 1 Viper.
Notes:
* Mine is stock ride height.
* I did not have to drive onto boards.
* Given the short distance between the front wheel and the front lift point, you need to place the quickjacks backwards so as you lift the car moves slightly backwards instead of forwards (it lifts in a slight arch and not straight up). This is a non-issue given the even weight distribution of our cars.
* The clearance between the rubber block and the lift point is only about 1mm at the front of the car and about 6mm in the back.
* If you go for the 5000TL, that should give you 0.5 inches of extra clearance as you slide them under the car
Photos:
Venamous54
USA
Thank you for the information. I've been looking at several different portable lifts for my GEN III.
