Radio?
shmoos
Lawrence Twp, NJ
This message is for the NJ members. I live in the Trenton area and just got a 2000 gray viper. I want to put a new radio in it. I have the radio already but want to know a good place to have it installed. My local dodge dealer said they would put it in as long as they didn't have to Cut the wiring harness. I have the harness kit. I beleive there hourly rate is $98. I am not a cheap person but if I can get it done for less per hour I will as long as the place that is doing it is profesional. I am will to drive if I have to. Please pm me if you know of anyplace.
dave6666
I had the OE radio replaced in my '01 GTS with a new Alpine. Kept the OE amp and wiring to it. Took quite a bit of wire splicing to match new radio to old harnesses.
Good luck on your installer search.
And stand behind them and watch them if you can...
shmoos
Lawrence Twp, NJ
I was planing on standing behind them. I found a wiring harness that is suppose to work with the factory wiring harness.
The local Dodge dealer will do it. I just hope the harness i got works with the car. If not. then i will have to splice into factory wiring.
I keep you informed.
shmoos
Lawrence Twp, NJ
Thanks. I was looking into getting the royal Purple oil. I had good luck with it on my S2000 i had.
dave6666
I would be interested in that adapter harness, as no one to my knowledge has ever been able to come up with one.
sdaddy
Jacksonville, FL
A Dodge dealer Viper Tech scratched the dash so badly on my 94 hooking up a factory CD player (actually he tried and then told me he could not make it work and he needed to send it out to a car stereo shop) that I had to replace the dash. I took it to Sound Advice and they got it installed and working, but they added a few scratches of their own. I think the CD player install was around $100, and then $470 for a new dash. And that was back when you could still buy a new 94 dash.
shmoos
Lawrence Twp, NJ
I am planning on putting the car in for the radio next week. I will let you know if the harness works like it says. I might even do it myself. Havnt decided yet. but ether way i will let you know if it works or not.
dave6666
The pin outs on the OE DIN rear amp cable on my '01 GTS were as follows, as needed for my Alpine CDA-9885 head:
Red Unshielded - Front Right Audio
Yellow Unshielded - Rear Left Audio
Brown Unshielded - Ground All Channels
Gray Jacket Sub-Cable White - Front Left Audio
Gray Jacket Sub-Cable Red - Rear Right Audio
Gray Jacket Sub-Cable Shield - Remote Amp Turn On Signal
Black Unshielded - Unused
ViperJohn
Maryland
I would be interested in the wiring harness adapter as well. The only thing I have been able to find is the 16 pin adpater to hook up an Alpine head unit, which is a female connector. I have not been able to find the radio replica,(male connector).
Let us know if it works.
Raymond
