Rear tire size ???
grayman
Prince Frederick, MD USA
I have 345/30 ZR19 Michelins on my HREs. Does anyone have, or for that mater, does anyone make, a larger tire that would fit on a Viper. Would love it if a manufacturer made for example a 375 rear tire size and it would fit in the Viper wheelwell. ???
MtHam ACR
Mt Hamilton, CA
hate to break up the party, but you're probably gonna need something along the line of a 14" rim to run 365mm tires, and 375mm would be happier with something closer to 15" than 14"
Eric
(all for wide, but without that compromised sidewall look)
G
grayman
Does anyone know if ANY manufacturer makes larger than 345 series tires????? Secondly, if they do, would they even fit the wheelwell with the right offset rim???
Mike Brunton
N. Andover, MA
I don't know of any production tires larger than a 345. However, if you can get enough people to buy them, many tire companies would probably do a run for you in the size of your choice. I bet you'd need 100 people or so to make it cost-effective, however. Try calling around. I talked to Nitto before about a custom run of 345-sized drag radials for stock Viper rear rims, and they WERE willing to listen, but wanted a pretty big order to make it worth their while.
As for the wheel, there is a good 1" of space you could use with a larger offset rim, and I think you could add 1/2" to an inch on the outside without it looking silly. So you could get about a 14.5-15" wheel on there with a little more offset and still look good.
BUT,
since no DOT tires exist in this size, you aren't going to find rims of this size either - so you'd be talking about custom rims and custom tires. In other words, VERY expensive. And without changing the setup at the front, you might very well screw up the handling of the car. And no doubt it would track the road a bit worse than it already does... AND you'd have to buy enough tires to satisfy you for life, or pay big bucks to get another run made.
My .02
FirecatF7
