Replacement for stock plugs?
bwhitmore
Sacramento, CA
I hear most everyone seems to use the Champions. Should I go Single or Double Platinum? I figure Double, but is it worth the extra $.
95Viper
Phoenix
Go with only stock, about 1.15 each. This isn't being cheap, they work the best in a stock.
95Viper
Phoenix
Not a bad idea, real easy to do, good to check old plugs for any signs of anything wrong. Clean around plug, use vacumn to **** out dirt around plug, pull.
Use antiseeze, tighten to 15-20 lbs. with torque wrench. Use rubber hose to assist threading in.
Atom
