Reverse gear - effort to engage
fanaticrom
Romania
Hi!
Just changed the clutch on the car (went for OEM). Something strange happened with the reverse gear.
All other gears work impeccable, but in order to engage reverse I need to push very hard to the right before pushing forward. It feels like I am pushing in a spring with very high resistance.
It wasn't like that before.
Any advice?
Thanks.
There is a solenoid that locks out reverse that is based on speed. It's spring loaded so you can push through it in emergencies, but it sounds like maybe you have a loose plug or something. Normally it's supposed to open under 3-5 mph I believe. Guessing when you dropped the trans that maybe one plug didn't get fully seated again.
sham5430
