Review for non Viper believers
RTTTTed
There's a war going on in the US right now. It's got nothing to do with
bombs and guns - but everything to do with firepower.
While all the US carmakers are rushing to get small, economical cars onto
their dealer lots as oil prices spurt to over $100 a barrel and house prices
plunge from their all-time highs, two of them are still locked in mortal
combat to produce the most heinous, fire-breathing production car on the
planet.
In the blue corner we have GM's 2009 Chevrolet Corvette ZR1. This
range-topping supercharged 6.2-litre missile bristles with carbon fiber -
bonnet and roof are now all the woven black stuff. It's so fast they've had
to rework the speedo so it now reads up to 220mph instead of the standard
car's 200.
Boasting more power than NATO and more torque than the Women's Institute,
the ZR1, codenamed Blue Devil, also threatens to pull your face off in the
corners by generating almost as much sideways gravity as a fighter jet.
You'll be able to see exactly how much on the Top Gun-style head-up display
- when you're not blacking out from the acceleration.
It's got plenty of other trick bits, too. A bigger, stronger clutch so you
can do bigger, longer burnouts. A six-speed close-ratio gearbox instead of
the standard car's arm-length throw, and carbon ceramic brakes, just like
the Corvette Le Mans cars. It even has suspension you can adjust to
track-level stiffness from the comfort of your heavily bolstered seat.
So, it seems fair to say, it's going to be a fearsome weapon when it arrives
in late 2008. Skylines, Ferraris, Lamborghinis... nothing will be safe when
the $100,000 ZR1 hits the streets running. Least of all the poor old Viper,
you'd think.
How on earth could the big Dodge beat the ZR1's Star Wars spec sheet? I
mean, it's great fun smoking the tires on the big Viper but it's hardly a
21st century device is it? It's still got a steel chassis and it hasn't got
any carbon fiber anywhere, for heaven's sake. It's about as modern as a
battering ram.
Well, OK, it's not the cutting edge, but the red corner has added a couple
of new tricks - and, yes, some carbon fiber - to the Viper playbook. And
it's confident its new $98,000 car, the ACR, can still take the fight to the
new 'Vette. It's not quite pitchforks versus lasers as, for all its trick
techno bits, the ZR1 is still also a big, pushrod-engined car at heart. But
it's not far off.
So why do the Dodge people seem so confident? Well, for a start, despite the
Corvette's Le Mans success and apparent technological lead, in Z06 form, the
Viper SRT-10 is the faster, better handling car. In all comparison tests,
the Viper has covered the quarter mile, the dash to 60mph and cornered
faster than the 'Vette Z06 could manage. That's why.
The how is a little more technical, but not much. The Viper is wider, lower,
longer and, despite appearances, has a seven-inch shorter wheelbase than the
'Vette. The big Dodge might tip the scales a couple of hundred pounds
heavier than the Chevy, but then its engine is a battle-ready 8.4-litre V10
that fires 600hp to the rear wheels. The Corvette Z06 has to make do with a
relatively weedy 7.0-litre V8 that can muster a mere 505hp to torture the
rear tires.
That's in standard form. In ZR1 spec, the 'Vette trumps the Viper's power by
a comfortable margin. So that should make it quickest through the quarter
and in a straight line. And the new suspension should shave a few tenths off
its lap times, so maybe it'll get a little closer in the corners, too.
But now that Dodge has fired back with the ACR - that's short for American
Club Racer - maybe it won't. The new Viper's engine remains as stock, so the
big 'Vette might win the straightline battle, but it's doubtful it'll win
the lap-time war because this Viper ACR, the third since 1999, is packing
some serious handling heat under its bodyshell.
As Chief Viper Development Engineer, Herb Helbig, said when he showed us
around the prototype ACR: "It's going to take a bit more than just putting a
supercharger on the Corvette to make it beat this." As we're going to
discover, he's not wrong.
Designed to be the kind of car you can drive to the track, thrash against
your friends, then drive home again, the ACR turns the already
uncompromising Viper into a just-add-numbers racer for the road. It's
lighter, better handling, faster stopping and more outrageous than it's ever
been before. Perfect.
It weighs in 40lb - half a tank of petrol - lighter than the standard car,
thanks to lighter tires, wheels and brakes. But it can shed another 40lb
with the optional ********* package in place. That deletes the audio system,
underbonnet sound-proofing, boot carpet and tire inflator, replacing them
with a lap timer and some carbon-fiber panels. It also brings the weight of
the car to within an ace of the weight of the ZR1, cancelling out the
'Vette's bulk advantage.
But, rather than making the ACR's top speed higher, the rest of its new bits
are designed to make the car quicker around a track than along the drag
strip. Instead of messing with the engine, which they reasoned makes more
than enough power, the Street and Racing Technology team worked on improving
the Viper's grip, to make more of the power useable more of the time.
This involved night after night in the windtunnel - after the Dodge NASCAR
team had finished with it - subtly reworking the Viper's shape to increase
its downforce. Rather like the Ferrari Scuderia, the final shape they
emerged with isn't that much different from the standard car's form, but the
differences to the car's performance are significant.
Where the standard Viper generates about 100lb of downforce at 150mph (which
is better than the majority of big sports cars - most generate lift at
speed) the ACR makes 1,000lb of downforce at the same speed. What that means
is that, when the car hits naughty motorway speeds, an invisible baby
elephant appears on the roof of the car and squashes it into the road.
'Instead of messing with the engine, the Street and Racing Technology team
worked on improving the car's grip'
This allows the Viper to corner at previously unthinkable, spin-off-and-die
speeds. Even though the team were still doing final tests on the aero kit,
which involves an adjustable depth front 'fanged' splitter, a good sized
rear spoiler and all manner of bodywork tweaks, they reckoned they were
seeing around 1.5g of lateral, lunch-loosening g in fast corners.
What allowed them to come back and tell us that fact is the new suspension.
Supplied by KW Suspensions and tuned specifically for track performance, the
ACR's set-up is adjustable for damping and ride height without removing the
wheels. It's a long way from the convenience of the Corvette's push-button
system, but then it's a lot more serious, too.
The brakes are remarkably similar, though. Both have huge carbon ceramic
brakes that are almost the same size as the wheels, and calipers the size of
toasters. So you can expect similar, freeze-frame style,
get-your-eyeballs-off-my-windshield braking performance from the pair of
them.
Well, I say you can expect it for both of them. While we are going to have
to find out later how the ZR1 drives, I'm going to know about the ACR in
less than one minute as I've just heard the car bellow noisily into life in
the garage behind me. That means it's my turn to thrash it - there is only
one car, so no pressure - around the track here at Willow Springs in the
high desert above LA.
As I pull on my gloves, the clear blue sky suddenly darkens, the wind picks
up and I feel a few drops of rain on my face. Oh great. I look at the ACR's
cut-slick Michelin Pilot Sport Cup tires, remember the 600bhp output and
swallow hard. The invite said to bring a fire suit and helmet. But I didn't
get the invite, so I turned up in jeans and sunglasses. Hmmm.
No time for second thoughts now, though. Strapped into the car in a
four-point racing harness, all the trademark Viper cues are there. Cramped
cabin, check. Just see over the steering wheel, check. Earthquake exhaust
note, check. Heartrate over 150bpm, check...
As I fiddle nervously with the few controls that are left in the cabin after
the ********* boys have done their deleting, Herb Helbig leans in through
the netting window, pulls the cigar from his mouth and shouts at me: "Just
remember that the tires are cold. And watch the wind out of turn eight. Put
a wheel off the track there, and your drive is over. D'ya hear?"
Cold. Wind. Off. Over. I nod responsibly, then jam it into first and blast
off down to turn one, like you do when you're in a 600bhp race car. But like
you probably shouldn't in a 3,300lb Viper on cold tires on a track you've
only seen recently on a couple of sighting laps in a van at 40mph.
Before I go any further, I should explain that a Viper has the laziest power
delivery this side of a water wheel. As the road speed soars, the engine
note hardly changes. Add to this the wide-spaced gears, two of which are
largely unnecessary due to the endless amount of torque and, despite its
ferocious appearance, it is a strangely relaxing car to drive fast.
Which is my excuse for why I've just arrived at this first left hander 30mph
quicker than I probably should have. I think about panicking but there isn't
time, so I just hit the brakes, slip it down a gear - more to use the new
slick shifter than for any need - throw it in and get back on the gas. The
ACR is not in the slightest bit bothered.
So I do it again in turn two, a double apex right, and the Viper just sticks
and goes. Turn three, a tight uphill left hander that flicks right at the
top of a small hill into turn four. It would be a challenge for any car to
keep itself together through this, particularly a big fella like this Viper.
But it's not even vaguely upset by it.
'The steering is meaty and direct. The grip is astonishing and it never
seems to lose its composure'
Turn five, easy. Turn six, a blind crest onto the back straight, not an
issue. Turn seven, really just a kink, like it's not even there. But then
comes turn eight. This has to be one of the fastest corners on any non-oval
track in the US. A tightening radius right, I've driven a couple of cars
around here that have tied themselves in knots - along with my guts - trying
to get though and out of it cleanly. If anything was going to go wrong in
the ACR, this was going to be the place.
Needn't have worried. Even hopelessly off-line, the Viper can be adjusted
with all the ease of something half its size. It's not quite as easy as an
Elise, but it's several miles better than anything else of this size and
power. The steering is meaty and direct. The grip is astonishing and it
never seems to lose its composure. Oh, and it's very, very fast.
The whole experience was completely different to how I had imagined it would
be. Rather than having to rough handle some wheezing old nail around the
track, the ACR was fast, smooth and amazingly sure-footed.
Which is the type of car even quite inexperienced gearheads could buy, drive
to the track, race without crashing, then drive home again. And, as that's
exactly what Dodge tried to build with this car, it looks like it's made a
direct hit.
We know the alloy-framed ZR1 is going to be good on the road, and will
probably win that battle against the ACR. It wouldn't be that hard after
all. But having driven this big new Viper, I'd say the new 'Vette better
have something very special up its wheel arches or this is one war, on the
track at least, it could very easily lose.
Pat Devereux
I noticed that the only car considered competition for the Viper ACR is the ZR1. Notice no little wannabe supercars involved.
Ted
chimazo
Clarksburg, MD
them.
Except that the ACR uses 14" ft/rr StopTech slotted 2pc. iron rotors, not 15.5" ft/15" rr ceramic rotors like the ZR1 has.
R
RTTTTed
For the brakes I suspect he was referring to the pads. I read the same info on the brakes that you did. I'm not sure when the 09 vette will be sold so no point in disagreeing with other written stuff until there's actually a car to check?
My buddy Chris Guyer copied it and passed it on to me, I copied and pasted for you guys. I'd guess that Pat's another test writer since he says he was talking to Herb Helbig. Almost bought a TT Viper from Chris Guyer at Premier Auto, then he helped me buy a set of used Belanger Headers. He's often involved in Viper testdrives and photoshoots etc.
Ted
ccbatson
I think it is a British magazine from last month...maybe Top Gear?
Dads Toy
Kansas City, MO
Nice article. I personally do not care which car is faster or corners better. I am just happy to be in a time where these types of cars exist and we can actually have a chance to buy either of them. You do need a pretty big piggy bank but still way cheaper than most European super cars.
R
RTTTTed
If I would have written it I wouldn't have done any whining.
"Cramped cockpit, check". Funny, he didn't say he was a fat pig? Have trouble squeezing your BIG Butt into the seat of a Viper? Lose some weight as the car performs better with a driver under 200#. 160# in my case means I'm faster??? Lol. Can't remember the last time I sat in a Fighter Jet with a "roomy cockpit".
The Viper corners so well that a roomy cockpit would be a safety factor. No cupholders is so that you don't have to burn yourself while blowing away those vettes. Obviously it would not be a safe idea to have room for stuff/junk to fly around the cabin while driving these cars.
I'm sure there's many that agree with me on this?
Ted
