Snake Eyes
- Joined
- Aug 8, 2003
- Posts
- 28
- Reaction score
- 0
I have a 98'GTS and with the exception of A complete Bellanger system, Smooth tubes & K&N's it's stock. I have 15K burning a hole in my pocket the mods I'm purchasing are listed below, My question is am I missing anything in terms of re-enforcement. I don't want to install all of this and find out that there was something I should have done and as a result broke something :
ALREADY HAVE:
Bellanger 1 3/4 Headers
Bellanger Free flow cats
Bellanger Cat back
Tubes & Filters
GOING TO HAVE:
Roe S/C w/8lb pully
Larger injectors
fuel pump voltage booster
70mm Throttle bodies
1.7 Roller Rockers
stage III Head cam combo (Loaded with all the goodies)
Heavy duty half shafts
Steel brake lines w/ slotted rotors & new (EBC) pads
Kumhos
Also has anyone ever had the Roe ported to match 2.02?
Finally What kind of estimated RWHP would this produce?
I am a mechanic by trade and do all my own work. So yes this can be done for 15K. The Head/Cam are used.
Thanks in advance!
ALREADY HAVE:
Bellanger Cat back
Tubes & Filters
GOING TO HAVE:
Roe S/C w/8lb pully
Larger injectors
1.7 Roller Rockers
Kumhos
Thanks in advance!
